Bottom Swage
This is a bottom swage I made from some scrap A-2 I found at work, it had already been drilled and cut. Funny how you see things as tools, and no longer as scrap. I just clamped the two halves together and MIG welded them to a plate. I did a forge heat treat on it to add some durability to it.
I started setting certain tools at a 45 degree angle to the hardie hole. I find this gives a more natural position at the anvil. With both hammer and stock at a 45 degree angle across the front of your body this position works better.
I gave it a coat of Blorange paint in honor of Richard Thiebeau who paints his tools some pretty colors. It is a combination of silver, blue and a spattering of Kubota orange for good measure.
11263.attach
it looks like it will work real good...you might put a little pink paint on to keep it from growing legs and walking off!
also if you have any more of it; use two for a spring tool (top and bottom) to make balls on the end of a rod
When you wrote "Bottom Swage" as the thread subject I imagined all kinds of jokes about swaging your bottom. Now though, I see from it's shape that's exactly what you had in mind! :o
Why does it scare me when I find someone else who thinks like I do?
Nice job Jeff.
Frosty
ahahahahahahahahhaha sorry but lmao. Cool swage though i want one but maybe with just one depression. What is the advantage of having two?
Nice!! I like the Martian camo pant job too!!!
Finnr
