December 28, 200817 yr http://www.iforgeiron.com/gallery/showphoto.php/photo/12818][img.] A new patch knife. Edited December 28, 200817 yr by Messerist photo
December 28, 200817 yr Nice work on that one i like the upswept blade. Rainsfire a patch knife is used to cut off your patches when shooting black powder rifles Bob
December 29, 200817 yr Real nice job. Gives me a bit of inspiration. A black powder rifle uses a patched lead ball loaded on top of a powder charge. Pour a measured amount of powder down barrel, place a flattened chunk of cloth on barrel end, insert lead ball until flush with barrel end, then cut all excess cloth away using a knife or other sharp object. Using a ramrod the patched ball is then rammed home atop the powder charge. All that is needed then is to use appropriate ignition method for style of rifle; primer cap, flintlock, etc. Ready, aim, fire; then repeat entire process again. After watching the actual procedure being done many are left wondering how bows and arrows were ever defeated.
