Posted (edited)
I now have access to a welder, and want to finally get started making hammers. However, I ama one-man operation, all hand tools. So I was thinking about making a hammer jig like the one Rich (rthibeau) has for his fly-press. It'll a gullitine type contraption, and will have the bolts on the bottom to keep the hammer head in place. Then, I will have inserts for the jig. Three slits. I will then punch and drift by hand. I'll also have a sacrificial drift that will be used for flattening the buldge. The welder is to weld up the jig. This jig will just drop in hardy hole, I'll through the slit in. Heat the head, throw the head in, and start pounding. Now, any ideas or things to do or not to do with this jig?
Edited by m_brothers
Posted
Okay, I'm gonna show my lack of knowledge here. Why do you need a welder to make a hammer. I'm not being smart maybe there's a technique I have not seen or heard of. I am genuinly curious.
John
Posted
I bought myself a fly press when I set up new workshop with lots of plans in mind for its use (I've not got it up onto a stand yet though). One thing I thought about was for punching holes in axes and hammers :) Being new to fly presses though I've not thought about the tooling.
I don't suppose you've got a link to the punch jig you mention? I can't find it anywhere!
Posted
John
Probably so he can weld up the jig I'm guessing..
Posted (edited)
Nope Alwin, I'm not looking for that. But thanks anyways. But I just need suggestions for how to go about making my jig, I have a general idea, but want any hints or pointers first. OR NOT TO DOs.
BTW, this is the BP: http://www.iforgeiron.com/index.php?option=com_content&view=article&id=105:bp1003-&catid=29:blueprints-1000&Itemid=26
Yuo forgot the linky. Lol. :)
Posted (edited)
Dave Budd: http://www.iforgeiron.com/Blueprints1000/BP1003hammer_eye/DSCF0149.JPG
http://www.iforgeiron.com/gallery/data/645/medium/PunchingHammerEye.JPG
The first link is to Hofi's jig in BP 1003, he uses it in a multi-ton big press. The second link is the jig I made for my flypress.....not as heavy duty or intricate, but functional for a flypress.
John: I don't see why it wouldn't be worth the effort to weld the jig up and see how it goes. All you need is something to hold the hammer blank in place while a slitter/punch/etc is pounded in to it. And to hold the slitter as well. A guillotine(sp?) tool thingy sounds interesting......make it heavy duty and weld it good.
Edited by rthibeau
clarification
Posted
M_Brothers,
Thank you for the clarifacation. Sometimes I am a little slow on the pick up. I sometimes have tunnel vision. Good Luck on your gig and your hammers. Post pics when yu get one completed (post pics of the gig also)
John
Posted
thanks Rich et al, that's great! The channel idea is pretty much what was floating in my head, but Hofi's set up is something special!
All I need to do now is get teh stand for teh press built, then mount the press, and then I can make some tooling :rolleyes:
Posted
Have you considered punching the eye by hand and foregoing the jig and press?
If you are going to use a press, make sure that the plate that the jig/tooling is welded to is VERY sturdy - I'm thinking 2 inches plus. I know that 1 1/4 inch plate will flex.
I recently tooled up a friend of mine who has symptoms resembling Parkinson's - trembles!
He wanted to make hammers so we mounted a slot punch into his #5 Fly press. The receiver/stripper combo was welded to a 1 1/4 inch thick plate. and secured to the base of the press.
We were going through 1 inch stock from a gas forge in 7 bumps. I was surprised at how much the base plate flexed. Also, the tool carrier at the bottom of the screw thread moved too much. It was too far out of the ways or guides. We moved up to 3 inch thick material to do two things
1. Reduce the flex AND
2. Place the tool carrier up into the guides to prevent sideways movement.
Posted
On my #6 flypress, I have a piece of steel 2" x 10"w x 20"L bolted to the base of the press to act as the table. I drilled and tapped it in various places and all my jigs or toolings are bolted to the steel table.....makes for very sturdy support.
