DUNSTAN Posted September 27, 2008 Share Posted September 27, 2008 I'm new to this, has anyone had any luck with using a shop vac as a blower? Quote Link to comment Share on other sites More sharing options...
hibjib10987 Posted September 28, 2008 Share Posted September 28, 2008 I had some luck. You need to put and extra long hose on the end and snake it for a while or your stream will be to strong and it burned through my coal like paper Quote Link to comment Share on other sites More sharing options...
Max Mulholland - Tetnum Posted September 28, 2008 Share Posted September 28, 2008 i have used one for the past year and i finaily got a 3/4 inch ball valve and it works great for me in my forge Quote Link to comment Share on other sites More sharing options...
DenK Posted September 28, 2008 Share Posted September 28, 2008 I use one,with a dimmer switch to control the blast.Hopefully it won't burn up the motor.If it does,then I'll be hand-cranking. :) Quote Link to comment Share on other sites More sharing options...
DUNSTAN Posted September 28, 2008 Author Share Posted September 28, 2008 Great ideas, a valve restriction or a reastat switch just might do the trick, I have had a problem with it getting too hot too fast,even after some venting off. Quote Link to comment Share on other sites More sharing options...
Dale Russell Posted September 29, 2008 Share Posted September 29, 2008 (edited) G'Day DUNSTAN , vac motor as blower , yeah i use 1 , 1500 w 240 v single phase ( Australian power ) hooked to a light dimmer switch ,,, i burn coke so i need LOT'S of air . I can go from a gentle breeze to blowing the fire out of the forge with a twist of a nob . Had this set up for over 12 yrs without any problems ( other then it can be NOISEY ) but after awhile i don't even notice . Dale Russell Edited September 29, 2008 by Dale Russell Add more info Quote Link to comment Share on other sites More sharing options...
