Fireplace Screens
Question for the group: Fireplace Screens: What is a good screen material to use? Any special tips as to how to attach the screen to the frame? And finally, where is a good place to get the screen material.
Thanks for your time and help with my simple question. Jim C.
For the screen, you may try some light guage expanded steel, which should be available at a steel yard or at a hardware store in small quantitys.
McNichols Wire sells fireplace screen and a 6 or 8 mesh is a good size. However, it is somewhat expensive so you may want to contact a local smith who has some if you only want to do one or two. McNichols has a $100 minimum - I was able to talk them into giving me a piece 17' long x 36" wide. They can also sell you other material types such as brass, copper, stainless, etc.
Dona Meilach has a book called "Fireplace Accessories" which is a good source of both design and some degree of technique. You will probably need to make a set of stretching tongs to get the wire taut and that is covered in the book.
did I mention that the harware cloth was only $8 after tax? Just thought I'd add that after seeing the websites with $100 min order and min 18sq ft order @ $4.17/sq ft.
Thanks for the information all.
Kristopher -- nice work at your site.
Jim C.
Thanks! (and my inlaws live in Perry, too)
To be fair, I can't really afford the more expensive screening materials.... If I could, I would have used something different but it's economics meets immediate need. Post pics when you're done
Jim,
Mike George had a nice looking screen in the gallery at our last conference. He obviously has a source for mesh.
Don't get hung up on screen or mesh for a fireplace screen. Try etched glass, or stained glass, or hammered and punched copper sheets.
