Montgomery Ward 230 welder
Welcome from the Ozark Mountains. If you don't have an owners manual, you can download one from here. I believe the 230 draws a max of 230 amps. I would go with a 50 amp breaker & # 8 copper wire. I'm sure Steve will be along to correct me if I'm wrong.
http://vintagemachinery.org/pubs/detail.aspx?id=20781
Semper Paratus
46 minutes ago, Kenny P said:
I have the old Montgomery ward 230 welder. I’m wiring my shop and don’t see information on what it draws so I need to know the wire size and breaker size to set up.
thanks.
ken
and here I come along lol
230 amps is OUTPUT not the draw. which would be more than 99% of what all houses have available.  According the the welders back plate I found on the internet, it draws 48 amps max, so connecting to a 30 amp dryer plug will work for most things, the 50 amp stove plug for anything it is capable of doing
What plug is on it now?
If you google it, the NEC has a special table for calculating the required wire gauge for dedicated welder circuits.  You can get away with a lighter gauge since the limited duty cycle at high settings prevents heating the wires as much as a constant load would.  Of course, there's no problem with using heavier wire than required, but copper isn't cheap these days . . .
This only works if you adhere to the duty cycle by watching the watch. The new welders have a cutoff when you get it to hot, but the old welders just start burning varnish. Ask me how I know.:D
