Jason Fry Posted April 4 Share Posted April 4 I'm pondering a volcano themed knife. My mind wandered from Indian George using his wife's ashes in a damascus canister to "what would volcanic ash in a canister do" to "could you use volcanic ash for flux?" What do y'all think? Recipe for disaster? Quote Link to comment Share on other sites More sharing options...
Frosty Posted April 4 Share Posted April 4 Depending on the volcano and how far from the vent you collect it the "ash" tends to be varying % of silicate. As a flux it'd probably work a treat for wrought iron. I don't know what it'd do in canister. Why not experiment by including a quantity of fiberglass insulation in the canister. I'd anticipate a chance of making a "FAUX" wrought iron. Check with a local masonry supply for powdered glass, it's commonly used to make plaster stiffer so it doesn't sag from moldings or lath and plaster walls. It's also used to reduce the fluidity (slump) of concrete. Could be a fun experiment and who knows maybe marketable stock. Here's a little thought experiment, un-twist cable and powder well with crushed glass and weld up. Just be aware molten glass is about the stickiest stuff I've ever encountered in my shop. I was slumping frit in some piece and it was months before I stopped seeing molten glass sticking to pieces and had stringers floating around the shop. I think a canister would be a REALLY good idea. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
George N. M. Posted April 4 Share Posted April 4 Volcanic ash is basically silica. So it would be like using very fine sand as a flux. I have used fine sand but it has a higher melting point than borax. So, even melted it is more "gummy" than borax and will not penetrate any voids as easily. You could also mix it with borax. You would have to experiment with various ratios. "By hammer and hand all arts do stand." Quote Link to comment Share on other sites More sharing options...
Jason Fry Posted April 4 Author Share Posted April 4 That's kinda what I was thinking. More of a novelty flux than anything, but sometimes novelty sells Most of my damascus I use kerosene and go from there, with borax sometimes on the second pass if the edges don't look like I want them to. I'm going to just have to try it. Even if it doesn't work well, the steel will still have "some volcano in it." Quote Link to comment Share on other sites More sharing options...
