December 15, 20223 yr clarification diagonal beams chevron i beams hi, sorry for the bizarre and bizarre question, could some kind user with notions of engineering and physics kindly explain the chevron beams, in Italy I think they are the diagonals or the arrows or braces, I think they are used to strengthen the portals or the connection between the column and the crossbar to avoid that the angle closes, to reduce the light the span of the bridges am I right? are coupled by welded plates right? on wikipedia or other search engines I have not found any feedback, thanks and sorry for the bizarre and bizarre question, thanks again greetings.
December 16, 20223 yr Nothing bizarre about the question Angiolino. The diagonal members prevent the structure hinging at the corners and collapsing. If you built with just vertical posts and horizontals top and bottom, any lateral force will cause it to move, the connections acting as hinges. Add a diagonal (cross brace) and the structure can NOT deflect without crushing or tearing the diagonal. These are good experiments to model with "popsicle" sticks and tacks or an erector set. It makes a simple square or box into a number of triangles and triangles are as strong a structure as can reasonably be made. Frosty The Lucky.
December 16, 20223 yr I wonder Angiolino, are you building something, brainstorming or just curious? I learn things from many of your posts and the replies you get. Thanks.
April 24, 20233 yr Author thank you, I don't build anything I try to learn as a self-taught, unfortunately I have not been able to study, returning to the question these are truss-type reticular structures, just self-supporting, the structural nodes would be hinged constraints which I believe prevent the structure from closing in their movement crossbar pillar am I wrong? I make you laugh, I was buying the " Meccano" constructions for children to do home experiments but they tell me that maybe it's closing too bad I have to find the right kits with the right components. greetings.
May 10, 20233 yr Angiolino, it seems you are trying Jerry's advice. Nothing to laugh at. I wish I could advise you, but like I said, I'm learning right along with you. Keep seeking the knowledge you are looking for. You will find it.
