June 16, 20224 yr Contact the maker if known and maybe they know the steel, if not I'd heat it past non magnetic and quench it in oil, if it's not hard enough quench in water, then I'd temper it over the forge to dark straw/ nearly purplish color. I do the axes I make the same way. ~Jobtiel
June 16, 20224 yr Where at home might that be? The previous answer is how I would do it also. Test for hardness with a file.
June 24, 20224 yr Remember: if you are guessing at the heat treat you can't be upset if it selfdestructs during or afterwards.
