Jason W Posted May 14, 2022 Share Posted May 14, 2022 Has anyone had any experience with a Marshall Excel regulator? I'm having some challenges with mine. I bought a new forge and I'm just setting it up. The regulator has a turn knob that either increases or decreases the psi of the gas but no matter which way I turn the knob the regulator gauge hits the pin past 30psi. I've seen this forge run at 1 psi on youtube and know that 30+ is way too high. FYI it's a Mighty Forge draft pro. Any ideas? Thanks. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted May 14, 2022 Share Posted May 14, 2022 Have you contacted Mighty Forge about the problem? I just went their web site and it looks like a very good forge to me. This thought just came to me are you turning the knob all the way in (clock wise) to start? Then after opening the tank valve slowly turn the knob left (counter clock wise) to the pressure you want. Quote Link to comment Share on other sites More sharing options...
Jason W Posted May 14, 2022 Author Share Posted May 14, 2022 (edited) I did send them an email just before I posted this question so they haven't had time to reply to me yet. It's a great forge and I believe it will be very capable when I get this minor issue sorted out. I was hoping someone here may have some knowledge on the subject. Edited May 14, 2022 by Mod30 Excessive quoting Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted May 14, 2022 Share Posted May 14, 2022 I've never used that particular regulator but if the knob spins fairly free then the diaphragm is backed all the way off wide open. Most are shipped that way. You have to compress the diaphragm spring by turning the knob to the right. Quote Link to comment Share on other sites More sharing options...
Jason W Posted May 14, 2022 Author Share Posted May 14, 2022 (edited) Thanks I'll give that a try and see if that fixes it. That didn't seem to work but when I turned the propane off then turned the knob clockwise/counter clockwise on the regulator I hear something internally clicking and the psi gauge increases and decreases so I think I might pull it apart tomorrow and see if something isn't lining up quite right. Edited May 14, 2022 by Mod30 Excessive quoting Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted May 14, 2022 Share Posted May 14, 2022 I wouldn't take it apart, been there done that and didn't even get a T-shirt they are hard to put back together without having a leak. Every regulator on my tanks do make a little sound (crunching) when compressing the diaphragm spring. Just turn the knob down till it stops (tight). Then open the tank valve and slowly turn the knob left watching the gauge. By taking the regulator apart would void any warranty. Quote Link to comment Share on other sites More sharing options...
Jason W Posted May 14, 2022 Author Share Posted May 14, 2022 Thanks again I'll give it a go in the morning and see how I make out. Cheers. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted May 14, 2022 Share Posted May 14, 2022 You might want to edit your post and remove the quote. Quoting the post just before your reply is frowned upon. The quote feature Quote Link to comment Share on other sites More sharing options...
Jason W Posted May 14, 2022 Author Share Posted May 14, 2022 Good to know thanks. Quote Link to comment Share on other sites More sharing options...
Jason W Posted May 14, 2022 Author Share Posted May 14, 2022 Aaand it was my lack of ability reading instructions. "Out" to the forge not "out" to the propane tanks. I had it on backwards... It's alive! Alive!!! Quote Link to comment Share on other sites More sharing options...
Frosty Posted May 14, 2022 Share Posted May 14, 2022 On any device with something flowing through it, liquid, gas, whatever In/out is the direction of the flow into and out of the component. Propane flows OUT of the tank then INTO the regulator and OUT to the burner. Make sense? This sort of thing is just part of the learning curve. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Anachronist58 Posted May 14, 2022 Share Posted May 14, 2022 Love it! Happy forging! Robert Taylor Quote Link to comment Share on other sites More sharing options...
