Heavy hammer Posted January 24, 2022 Share Posted January 24, 2022 What is yalls choice acid for etching steel? I have used a few different acids and I can get really good results with mild steel and ferric chloride but for high carbon steels it doesn't affect. What acids and process have worked for yall? I usually put a piece in for a long period Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted January 24, 2022 Share Posted January 24, 2022 Are you etching letters into the steel or are you etching a pattern welded piece to show the pattern? If it's the latter then the alloys used make a difference with what works best too. Quote Link to comment Share on other sites More sharing options...
Heavy hammer Posted January 26, 2022 Author Share Posted January 26, 2022 Thanks for the response! I've been doing weeks of research and I'm planning on trying my hand at wootz following al pendrays methodology. I was wondering what the best acid would be for steel in this category as far as I know carbon iron and vanadium are the most prevalent metals the rest are in ppm. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted January 26, 2022 Share Posted January 26, 2022 Traditionally Zag was used; have you read the thread on Wootz Etch at bladesmithsforum.com ? Ferric Chloride, Nital, HCL, lots of stuff has been used successfully, depending on the details... Quote Link to comment Share on other sites More sharing options...
Frazer Posted January 26, 2022 Share Posted January 26, 2022 I'm no metallurgist, but I remember the patterning of wootz has to do with the carbides that precipitate out (I think the vanadium facilitates this). So you pretty much have a monosteel with bands of carbides interspersed throughout the material; that's different from the etch/resist patterning of modern damascus. I think FC is still the way to go, but have no idea what the concentration of the FC should be (I usually dilute mine) or the soak time. I remember seeing a really interesting thread on crucible steel on this site. Have you done a site search on the topic yet? Sounds like you'll want to experiment with different acids (ferric, muriatic, vinegar maybe, coffee etc.) and see what results you get. I wouldn't expect a whole lot of contrast until you get the whole process right, but what do I know? Quote Link to comment Share on other sites More sharing options...
Heavy hammer Posted January 26, 2022 Author Share Posted January 26, 2022 (edited) 37 minutes ago, ThomasPowers said: Traditionally Zag was used; have you read the thread on Wootz Etch at bladesmithsforum.com ? I have not, but I will now! I believe in a video I watched al used nital witch will probably be what I do. I'm trying to follow his work almost religiously, i apologize for asking when I knew of nital and had just forgotten it 34 minutes ago, Frazer said: I'm no metallurgist, but I remember the patterning of wootz has to do with the carbides that precipitate out (I think the vanadium facilitates this). No this is great info thank you! You are correct the pattern is not dependant on etching IT is dependent on the carbide structure throughout the steel. However to make whatever pattern I do get stand out a little more I plan on doing a short Etch. Thank you a bunch! Edited January 26, 2022 by Mod30 Trim quotes. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted January 26, 2022 Share Posted January 26, 2022 I was the assistant when Al did the demo for Quad-State one year just to be able to ask him questions...Nital is one of the common metallurgy etchants that most hobby folks are not aware of, (or have access to: like the picric acid etches that get you on certain lists just for asking about sources...) What's that old saying: "Don't etch your steel before it's cast!" Quote Link to comment Share on other sites More sharing options...
Frazer Posted January 26, 2022 Share Posted January 26, 2022 DanielC was the guy I was thinking of that was exploring crubible steels. He shared some interesting pictures here and here . It seems like quite the process to undertake. I'm not sure where I'd start! Maybe you could reach out to him, he hasn't visited since July 2021, but who knows. He can probably give much better info than any video. P.S. welcome aboard, please read this first. You'll find useful information in there to help you get the most out of the site. P.P.S No need to quote my whole post, especially if it's the one just before. If there is one line/statement you wish to respond to, you can highlight it and click the "Quote Selection" box that appears. This saves bandwidth and people from needing to read the same thing twice. No hard feelings, just a general housekeeping note. Quote Link to comment Share on other sites More sharing options...
Heavy hammer Posted January 26, 2022 Author Share Posted January 26, 2022 48 minutes ago, Frazer said: No hard feelings, just a general housekeeping note. Thank you I will do that from now on! I appreciate it and I will try to reach out to the other user! Quote Link to comment Share on other sites More sharing options...
Frazer Posted January 26, 2022 Share Posted January 26, 2022 Best of luck to you and if/when you get started, please share your journey. I find the process fascinating even though I don't have the skills/know-how to do it. I would like to do a smelt someday, but that's beside the point . Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted January 26, 2022 Share Posted January 26, 2022 And remember folks that while all Wootz is crucible steel; not all crucible steel is Wootz! Quote Link to comment Share on other sites More sharing options...
Heavy hammer Posted January 26, 2022 Author Share Posted January 26, 2022 Exactly! I'm on the journey to recreate REAL wootz I'm very excited. And believe me the process will be shared here for all Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted January 26, 2022 Share Posted January 26, 2022 See if you can dig up a copy of Dr Feuerbach's Thesis on Crucible Steel in Central Asia; if you like to know the historical background of things. I was able to get a copy on disc when it was offered to members of the Archeological Metallurgy mailing list way back when. I also have a copy of the massive thesis on the monsoon wind driven smelters of Sri Lanka where they were making crucible steel. Also "Steel Making Before Bessemer: v. 2: Crucible Steel - The Growth of Technology" by K.C. Barraclough OUCH---some of those are now several times what I bought them for! Definitely try ILL *first*! Quote Link to comment Share on other sites More sharing options...
