August 24, 200817 yr i have been using blacksmithing coal for my forge but i get it from a ways away and there is another place that sells coal closer but i think its only household coal is that ok to use in blacksmithing?
August 24, 200817 yr Generally, no. It probably has a lot more sulfur, ash, and other junk you don't want. Of course, it may be anthracite ('hard') coal which may work. There are a few threads on here regarding using anthracite.
August 25, 200817 yr I have used anthracite coal since I started forging with satisfactory results. The nice thing about it is no smoke except when I use wood to get it started and no smell. I recently did a week long demo at our county fair. I had a fellow come up to me and ask what iI was using for fuel. He said he could always smell a blacksmith's forge but couldn't smell mine. The key to anthracite is good quality. I am fortunate to live in a coal mining county with a good supply of local high quality coal. Forge welding is tricky since it doesn't produce coke as the coal burns. the carbon content is higher which helps me case harden mild steel for chisels and punches. My advise would be to try some if you can get a small amount and see how you like it.
August 25, 200817 yr I don't live in New England, but I've heard that Aubuchon Hardware stores carry usable coal or can get it. It looks like they've got New Hampshire pretty well covered.
August 25, 200817 yr Author the first time i used my forge i used some old coal my grandparents used for a coal stove i think it was anthracite coal but that was my first time so i don't know if its better or not lol
August 25, 200817 yr I use the coal from Aubuchon all the time. It is good blacksmith coal from the pocahontas vain # 3, I think it is called saint nicholas coal. Aubuchon stores are located all over New England including NY. Also check the sticky at the top of this forum for the coal supplier list I am trying to build with all of the help I can get from members, you may find another supplier located by you. If you find and use a new supplier not on the list please add them to the list.
August 25, 200817 yr Without having tried the coal you are looking at we can't say; we're only guessing. My suggestion is to try a bit, see if they have a broken bag you could get cheap or a 5 gallon bucket worth if they sell in bulk. if it works well then you're ok if it works poorly then don't buy anymore.
August 25, 200817 yr Author ok i got 200lb of chestnut sized anthracite coal for $39USD which should mean i could get a ton for $390USD, i think
August 27, 200817 yr for any interested,on ebay a gentleman in santaquin, utah sells soft bituminous coal,just put in item #360079300495,he sells 100#,50#,and 25#.good for those on the west side of the continental divide.
August 28, 200817 yr Author lol to bad for me but i like the anthracite coal better then the blacksmithing coal i had to get my dad to drive me 80 miles to get, lol, its cheaper to and its a larger size
