ElijahJMHutchinson Posted January 5, 2022 Share Posted January 5, 2022 Hey guys, I'm new here and this is my first post. I have a forgemaster ferriers forge that I've been running for a while and the depth of the forge prevents me from working longer pieces of steel. I was thinking of cutting a 2" hole out the back of the forge so that I could use it for knife making as well as other long projects. Has anyone done this or does anyone have a recommendation for me? I am hesitant to cut a hole in my 600 dollar forge without asking experienced folks about it. Thank you guys! Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted January 5, 2022 Share Posted January 5, 2022 Funny, over the Christmas Break I swapped out my old homemade coal forge with an *older* one that had a cast iron firepot and a true glass enamel hood that fit it. I had to cut a pass through in the enameled metal hood and in the shop wall behind it---made it to fit a firebrick so I can block it off when not needed. Have you talked with the manufacturer about this? I would think it was not that rare of a modification? Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted January 5, 2022 Share Posted January 5, 2022 Well, of course you can do that; if it;s done very carefully, you won't even hurt that forge...much. Or, you can construct a gas forge for the purpose, for about the same amount of work, and some money added; leaving this forge intact. Quote Link to comment Share on other sites More sharing options...
