Rob Gunter's Super Quench Solution
  • 2 years later...
Is there a substitute for the Shaklee Basic I? I had a hard time remembering what the Shaklee company was.
I think there is, Harlequin. I'm not sure off hand of the amount, but Jet-dri for dishwashers can be used. I'll have to get back later with the amount, if someone else doesn't jump in with the info.
its primarily there as a a surfactant/wetting agent (so is the soap)
Surfactants: Detergent Chemistry
there is one good reason to employ Shaklee however
Products derived from natural, nontoxic ingredients -- once seen as fringe -- are now mainstream. LA Times
When Shaklee began searching for a green surfactant, the ingredient that dissolves dirt and grease, no chemical company seemed interested in inventing one made from vegetables. Not until Shaklee called Germany and talked to chemists at Cognis, a specialty manufacturer.
The result: a biodegradable mix of coconut oil and sugar.
Josef Koester, marketing director for Cognis' Care Chemicals North America, said his company created the coconut-and-corn surfactant by incorporating a simple concept: "Using less chemistry."
thats not to say Basic is one of those green surfacants....
I used a bottle of jet-dri (7.4 or .5 oz, i believe) and it hardens mild up not too bad. I remember reading elsewhere on the replacement. shaklee's is kinda hard to come by. kind of the amway thing
you can get almost the same results as super quench using iced salt brine. Just remember to move the steel around in the brine when quenching to cool it as rapidly as possible.
I have used simple green for the replacement and it works well.
Firegnome:)
8 oz of Simple Green?
