pnut Posted August 28, 2021 Share Posted August 28, 2021 I've been using the yellow PTFE tape for my gas line. I'm about to switch to Harvey white slow setting pipe thread compound since it's what the plumbing supply place near me stocks and I'm out of tape. My concern is that since I have to disconnect the tank from the regulator after every session that I'll have problems with particulate matter getting into the regulator. I plan on using a brass brush to clean the threads and fitting every time the same way I've been cleaning them up when using tape. Does anyone foresee a problem with this? Pnut Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted August 28, 2021 Share Posted August 28, 2021 On my tank connection, I don't use any tape or compound. Unless I'm not understanding your connection it's not required. If this is the connection don't use tape or compound as it is a ground mated fitting. Quote Link to comment Share on other sites More sharing options...
pnut Posted August 28, 2021 Author Share Posted August 28, 2021 That's exactly what I was asking. Thanks. Pnut Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted August 28, 2021 Share Posted August 28, 2021 You're welcome. On my setup, I have a plastic plug that screws into the valve and I wrap the regulator in a plastic bag to keep any critters out when it is disconnected. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted August 30, 2021 Share Posted August 30, 2021 WHAT HE SAID! Tons easier keeping them out than cleaning it out! Quote Link to comment Share on other sites More sharing options...
pnut Posted August 31, 2021 Author Share Posted August 31, 2021 Yes indeed. I bring the forge, hose, and regulator into my apartment after it cools down so there's a slim chance it'll be infested and use the plastic cap that came on the tank. Pnut Quote Link to comment Share on other sites More sharing options...
