evildeadash Posted March 20, 2021 Author Share Posted March 20, 2021 The picture really doesn't do justice, they look almost identical when running. If anything the back one might flare a little rich every now and then. I'll try the scale test tomorrow when I get done with the "honey do's". I have some K26 insulating fire bricks for forge doors. Thanks again guys. Quote Link to comment Share on other sites More sharing options...
evildeadash Posted March 20, 2021 Author Share Posted March 20, 2021 (edited) Fires forge up and got it hot. Put a shiny piece of 1/4 x 1 bar in. Took about 3.5 mins for it to get just at yellow hot. Tried brushing it but couldn't get any scale. Put it back in and got to same temp then tapped a few times with hammer. Got some scale but not much. Took these two pics after the forge was running for about 15mins. I had the door covered while heating up. Edited March 20, 2021 by Mod30 Resize photos Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted March 20, 2021 Share Posted March 20, 2021 It is burning clean and hot. Congratulations; you have arrived. Now, you want to start working on efficiency, before you run trough a lot of $$$ gas Quote Link to comment Share on other sites More sharing options...
evildeadash Posted March 20, 2021 Author Share Posted March 20, 2021 Does that mean I've graduated from the forge building section of IFI and I can use the rest of the forum?! Thanks again for the help. Quote Link to comment Share on other sites More sharing options...
Frosty Posted March 21, 2021 Share Posted March 21, 2021 That's one HOT looking forge you have there. I suppose we can loose you on the rest of the gang now. Go forth and be talkative! You do realize those thoughts you're having about how you're going to make your next forge are normal, right? We al have them and can look under a bench or behind something at our old forges for reminders of why we didn't do THAT again. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted March 21, 2021 Share Posted March 21, 2021 You know that you have a bad case of it, when you're busy designing the next forge, while completing the present one. Quote Link to comment Share on other sites More sharing options...
evildeadash Posted March 21, 2021 Author Share Posted March 21, 2021 No doubt and I'm helping a buddy from work build one plus another in Ohio. All b/s aside, if you guys come across anyone from the central Louisiana area that needs in person help, send them my way. I'll still be lurking around here to chime in with any help I can offer. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted March 21, 2021 Share Posted March 21, 2021 Next thing ya know you will be building a side draft charcoal forge like me. No sooner than I had the propane forge going good with help from a lot of great help here, I started on our charcoal forge. That's as far as I have gotten before life got in the way, then covid. All that's left is to line it with clay and shape the fire pot. I really need to get a movin on it. Quote Link to comment Share on other sites More sharing options...
