Wrappy Posted January 25, 2021 Share Posted January 25, 2021 So I am having issues with my forge It says I should be getting 2300+ temperature but I have only been getting around 1700-1800. I'm still relatively new to blacksmithing and it wasn't effecting me too much since I was only working on mild steel, which would work cold anyway. I want to start trying out new techniques like forge welding and carbon steels, so I want to know if anyone has ideas as to why its not hot enough? (I'm going to try messing with pressures this weekend, I think mine will work better with lower pressures) Here are some images of my current setup (also yes, I am going to apply a new coat as soon as the mix arrives) Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted January 25, 2021 Share Posted January 25, 2021 What did the manufacturer say when you asked them about it? Note that high carbon steels are worked and welded at lower temps than mild steels. Quote Link to comment Share on other sites More sharing options...
Wrappy Posted January 25, 2021 Author Share Posted January 25, 2021 Haven't emailed them yet, but after reading the manual again I think I may need to move the burner lower, If I can't fix it this weekend I will contact them though. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted January 25, 2021 Share Posted January 25, 2021 Could be your propane tank. That will have a safety valve in the shutoff preventing too much gas being released when opening the valve or in case of a bad leak in the hose. Try opening it slowly to prevent the safety from engaging. Did the regulator come with the forge and what is it's pressure rating? Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted January 25, 2021 Share Posted January 25, 2021 The photos show that your your forge is generating plenty of heat, and also why it isn't staying where you want it. You need to do a little more work on that pile of brick. Turn it into a baffle wall. There are other moves you can make, but that one will take mere seconds. Quote Link to comment Share on other sites More sharing options...
