December 31, 20205 yr Made this stand for Rigid #9 anvil. Has 3" cast steel wheels and handle. The legs are sand packed and welded. Weighs in at 96lbs.
February 14Feb 14 On 12/30/2020 at 6:11 PM, EricB1403 said: Made this stand for Rigid #9 anvil. Has 3" cast steel wheels and handle. The legs are sand packed and welded. Weighs in at 96lbs. How do I go about buying this stand.
February 14Feb 14 Vico- this is a 5 year old thread of someone’s custom build. If you want a stand that resembles this one, draw it from the above images and take it along with the material specifications to a machine or welding shop and have them fabricate it for you, or if you can do these things, do it yourself. This forum is full of inspiration, but isn’t really a markeplace….
February 20Feb 20 I like the handle and the mounting holes in the feet, I wouldnt know what to do, move it or tie it down?
