Larry Hemphill Posted October 17, 2020 Share Posted October 17, 2020 Hey all, I recently acquired a #129 Toronto, the previous owner must have been using the horn to cut with a cold chisel and the horn is all chewed up, should I weld everything shut and grind it smooth again, or is there a better option? Quote Link to comment Share on other sites More sharing options...
Branding Iron Posted October 17, 2020 Share Posted October 17, 2020 The best option is to leave it alone! Try using it for awhile as is and see if it interferes with your work (highly unlikely). Quote Link to comment Share on other sites More sharing options...
Larry Hemphill Posted October 17, 2020 Author Share Posted October 17, 2020 Thanks. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted October 17, 2020 Share Posted October 17, 2020 Welcome aboard Larry, if you put your location in your profile, you may be surprised how many members are near you to offer in person advice. Pictures of the anvil will help in answering questions about it. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted October 20, 2020 Share Posted October 20, 2020 Horns are generally soft on anvils; a less permanent change to the anvil would be to plannish any raised area from chiseling back down flat with the horn which will also hep minimize the divots. Quote Link to comment Share on other sites More sharing options...
