Rayjp Posted October 14, 2020 Share Posted October 14, 2020 Just exactly what the title is I’m making my forge and making my burners too and am wondering if there’s like a ratio for how many burners to make sure it heats evenly. The space inside the forge is just going to be a couple inches longer then a foot Quote Link to comment Share on other sites More sharing options...
Glenn Posted October 14, 2020 Share Posted October 14, 2020 What is the size of the forge you want to build? 2 inches longer than a foot is 14 inches but you also need the diameter and how the forge is being built. Is the forge being built from hard fire brick, soft fire brick, or a metal cylinder using standard type and style insulation, or other construction? Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted October 14, 2020 Share Posted October 14, 2020 Welcome aboard... if you put your location in your profile, you may find many members who are close enough to visit and give first hand advice. What Glenn said is basic to getting the best answer. Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted October 14, 2020 Share Posted October 14, 2020 If the forge is cylindrical, a 14" length would indicate a five gallon container; paint can, propane cylinder, etc. In that case one centrally located 3/4" burner is usually enough, and two 1/2" burners are superior. Quote Link to comment Share on other sites More sharing options...
Rayjp Posted October 19, 2020 Author Share Posted October 19, 2020 On 10/13/2020 at 9:18 PM, Glenn said: What is the size of the forge you want to build? 2 inches longer than a foot is 14 inches but you also need the diameter and how the forge is being built. Is the forge being built from hard fire brick, soft fire brick, or a metal cylinder using standard type and style insulation, or other construction? Right now it’s exactly 13 inches long, 8 1/2 across and the height hasn’t been set yet. And It’s made out older style almost terracotta like bricks. Another question I have is how much does the height make a difference because I could make it pretty much as many bricks tall as I want. Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted October 20, 2020 Share Posted October 20, 2020 Those bricks are all heat sinks reducing empty space with heat sinks will not improve performance; it will worsen performance. Quote Link to comment Share on other sites More sharing options...
