Anvil expertise
Richard Postman probably has the most expertise on Wilkinson anvils here in the USA.  Now if you want to know about the anvil and not about people expertise; I'm sure you can ask specific questions.
Note: the edge damage is typical for anvils that have seen a lot of use.  The cutting plate looks like it's been reworked to me; can you tell? It looks to be in using shape. Wouldn't make a bad starter anvil for a new smith.
  The Ring test will indicate if there are any hidden cracks and the Ball bearing test will indicate if it has lost it's temper in a structure fire.
The 153 pounds comes from the hundred weight system where the 1+1+13 weighs 112+28+13=153 pounds. It probably weighs slightly less now, but it's close enough. As far as any further information I don't have much else to offer. Regardless, looks like she's seen some heavy use over time, but she'll probably still outlive me.
