Reference for correct papers
Is there a reference guide for which 72" grinding/sanding belts to use, removing metal, sharpening, etc. to use?
Good Morning,
A funny thing happens. First you start with a 36 grit +/-, then a 120, etc. After you have used and worn a 120 or 180, you have a 240+/-. Buy more Coarse Belts, you will soon have higher grade belts by using the coarse belts first.
Well that depends on the grinder, whether you are doing slack belt, contact wheel, platen grinding,  the type of metal, it's hardness, heat treat state and if you are trying to preserve it, the types of belts, what you are trying to accomplish, personal preferences,...
