Goundry Forge Posted January 13, 2020 Share Posted January 13, 2020 I picked up the tool on the left of the picture at a flee market. Is it a punch or a drift? Paid $10.00 AUS for both. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted January 13, 2020 Share Posted January 13, 2020 Yes. Quote Link to comment Share on other sites More sharing options...
rockstar.esq Posted May 6, 2020 Share Posted May 6, 2020 First off, there is a form of farrier hammer which is like a ball peen but instead of a ball, it's got a spike. It's used in a devilishly cool manner to pinch out some metal at the sides of a horse shoe, which is then pulled down over the edge of the anvil to form what they call a "clip". As near as I can tell, the "clips" sit against the side of a hoof and keep the shoe oriented. You might have one of those hammers. Now it could also be a handled punch, but you're going to want to check the hardness on that tool before you use it as such. Striking hardened tooling with your hammer is dangerous. To the best of my knowledge, the main difference between a drift and punch is that a punch is creating a hole, whereas a drift is used as an "internal" anvil. In most of the instances where I've seen the term drift applied, the tool in question did not have a handle. So long story short, you've either got a unique hammer, or you've got a handled punch, all depending on the heat treating of the tool itself. The photo leads me to wonder if the "face" of the tool is swelling outwards. If so, you might want to dress that flush before using it either way as chunks can spall off and cause injury. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted May 6, 2020 Share Posted May 6, 2020 I vote for the Farriers hammer. Quote Link to comment Share on other sites More sharing options...
pnut Posted May 7, 2020 Share Posted May 7, 2020 Isn't that called a clip hammer? Pnut Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted May 7, 2020 Share Posted May 7, 2020 Yep, after a quick google search there are several farrier supply sites selling that type. Quote Link to comment Share on other sites More sharing options...
