Grinder Posted August 12, 2019 Share Posted August 12, 2019 Hi; I am working on a hydraulic press and was wondering if the dies should be hardened steel or can any steel I can find work. I' am leaning towards hardened steel but not really sure. Appreciate ant advice. Thanks. Grinder Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted August 12, 2019 Share Posted August 12, 2019 Annealed will work as cold steel is harder than yellow hot steel. Also depending on the size, a hot chunk of steel can possibly draw a temper on a hardened part. But if it is being used constantly a hardened die can last longer. Quote Link to comment Share on other sites More sharing options...
Grinder Posted August 12, 2019 Author Share Posted August 12, 2019 Thanks Biggundoctor. Maybe I can find a piece of railroad track to cut up. Quote Link to comment Share on other sites More sharing options...
Matt Marti Posted September 26, 2019 Share Posted September 26, 2019 If you are talking flat dies still try to find some tough. You will experience wallering on the edges you use the most for reducing stock. If its soft it will occur faster then its hardened. Quote Link to comment Share on other sites More sharing options...
