Larry Price Posted July 3, 2019 Share Posted July 3, 2019 Picked up this item that someone started to build a coal forge.Just need too weld up the side holes and get a grate for the center.The nice lady threw in a ASO and a handmade hammer:) Quote Link to comment Share on other sites More sharing options...
pnut Posted July 4, 2019 Share Posted July 4, 2019 What does the inside of the firepot look like? You could probably put some mesh for plaster or concrete over the bottom and put clay soil on top of the mesh. You will probably need to put clay in it anyway so you can make it smaller. A rim is a pretty big firepot that's gonna be fuel hungry. Look up what a ducks nest firepot is. I think that is what most folks do to forges made from rims. Good luck, pnut Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted July 4, 2019 Share Posted July 4, 2019 Acualy if you mount that hunk of rail vertically and forge on the 1-1/2”x3” end it will make a serviceable anvil. cast iron flora drain greats make serviceable grates for those old forges, tho a piece of 1/2” bent into Ann exaggerated “S” work well. Just squish the “s” so it is an “O” with a slash across it. Takes a long time to burn up 1/2” Quote Link to comment Share on other sites More sharing options...
