Food Safe Quenching
I am making a knife for a customer whom I know will probably use the knife for food.  I am using spring steel from a leaf spring and I want to know if I should use a certain oil, water, or brine.  What would work best for my situation and how is the best way to do it?
14 minutes ago, Steve Sells said:
I relocated your post to a more appropriate place, I suggest you read a bit here and you will find your answer, start with the pinned posts on heat treating.  Welcome to IFI
thank you for relocating, I'm just learning the ropes right now
You use the quenching medium that is appropriate for the alloy, not its end use. It won't matter as no residue will be left after polishing.
