Daniel Lemerond Posted April 13, 2019 Posted April 13, 2019 I got this hammer at a rummage I was wondering if anyone new the maker Quote
Frosty Posted April 13, 2019 Posted April 13, 2019 Welcome aboard Daniel, glad to have you. If you'l put your general location in the header you might be surprised how many members live within visiting distance. This general class of tool is held on the work by it's handle and struck with a hammer. That one specifically is a punch for: making, or shaping a hole or punching things say a lock or hinge pin out of a hole or bale. Visualize a really big hinge you wish to take apart. Make sense? If you're going to use it you'll need to grind off the mushrooming from the ends. The steel that's starting to curl on the struck end can chip and injure the user or someone close by. The mushrooming on the working (small) end just makes it work poorly even cause it to get stuck in a hole. I can't read the maker's name but it could be almost any tool company, these are a common top tool, available off the shelf new at industrial (real) hardware or tool stores today. Frosty The Lucky. Quote
Irondragon Forge ClayWorks Posted April 14, 2019 Posted April 14, 2019 Welcome to IFI, I always suggest reading this to get the best out of the forum. READ THIS FIRST Quote
