June 19, 200818 yr Hey folks, I have been itching to hammer out some khukri style blades, but I am worried about the heat treatment. I understand that the kamis who make them use water out of a kettle and pour it onto the hot blade...I guess they do this edge up? I would like to be able to heat the whole thing to critical temp and then harden the edge, and leave the back softer, but because of the curve of the spine I cannot do this, my tang would be as hard as the edge.:confused: So how do you folks deal with curvy blades?
June 19, 200818 yr You can full quench the blade then draw the back down with a torch if you want to have a softer spine. Or if it is suitable steel you could do it up with clay and full quench.
