Jim Munn Posted December 18, 2018 Share Posted December 18, 2018 Folks, I I have my first anvil. Believe it’s a Arm & hammer but thought you might help identify it. All it says is “warranted” “solid and “wrought”. it does have the arm and hammer stamped ito the side, stamped as a 131 lb. can you tell the age from the ser # 8875. I’m concerned about the crack you’ll see down the side. What can you tell me about it? Thanks much! Jim Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted December 18, 2018 Share Posted December 18, 2018 Looks like the heel weld is failing. You can treat the heel gently and make an adjunct hardy hole for hardy tooling or you can try Veeing out the crack and arc welding it up---preheat and post slow cool of course and use the proper rod and if you are not a really good welder---I'd not go that route. Not knowing what country of the 100+ that participate here I can't make a suggestion of where to go for such a welding repair---few professional welders have experience arc welding real wrought iron. A face shot is much more important than the base shot. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted December 18, 2018 Share Posted December 18, 2018 Welcome to IFI... Have you read this yet? It will help you get the best out of the forum. read-this-first/ Quote Link to comment Share on other sites More sharing options...
Fatfudd Posted December 18, 2018 Share Posted December 18, 2018 It MAY be a crack. A&H were known to be made from junk metal that was forged together to make the base. I have several that show the bases were rather poorly made especially my 433 lb shop anvil that has a similar split but was probably used in a rail yard and I've used for many years with no problem. If you are worried it wouldn't be hard to grind the split and have it deep welded to a point below the face which could be cooled with wet rags while welding. Its a nice anvil! Quote Link to comment Share on other sites More sharing options...
