BartW Posted December 12, 2018 Share Posted December 12, 2018 Hello Everybody; Just wanted to showcase a reasonably heavy treadle hammer. It started life as a guided helve hammer; but the central column isn't strong enough for that. So after some pondering; I turned it into a treadle hammer. And I specifically didn't choose the guided hammer type; but this type; because I had the option to make the arms really long; so the arc is from the user perspective almost a straight line. the anvil is a train axle; the hammer is a solid bar mild steel (3cm x 8cm x 100cm). I machines the hinges, the axles (30mm), the bearings (machined teflon) all myself on my lathe as practice, I plan to start on a real tire hammer next summer. One picture shows the hammer; the other shows it in use. The pictures are deceiving; the hammer and the anvil really do line up straight vertically, and the arms are perfectly parallel. It hit a LOT harder then you would expect; especially in the second and the third hit when you are building up momentum. Now if anyone sees room for improvement, please tell me. P.S. yes, there's also a log-splitter press conversion; I'm waiting for longer hoses to mount it vertically. Quote Link to comment Share on other sites More sharing options...
lyuv Posted December 12, 2018 Share Posted December 12, 2018 I"m fantasizing about such a hammer for some time, and this looks like a design I can actualy make. Thanks for sharing. A little suggestion: seems the top horizonal beam is there "only" to keep the hammer vertical. If so, this is a light duty job, that can be done by a light weight beam (aluminum or wood). A heavy beam "steals" momentum and energy. Quote Link to comment Share on other sites More sharing options...
