File composition
19Branden86
I know some people make knives from old files. I have some old Nicholson pipeliner files that have damaged and rolled teeth. I'm thinking about annealing it and grinding down the tang to make a graver (may have to forge down part of the body behind the tang so as to have enough length for an engraving chisel). My question is, would file steel be good enough to work for this application?
Edit: obviously would need hardened and tempered afterwards
