Posted
Hi all,
I'm giving forging a go as a hobby and need some assistance. Do any of you know of a hose with a high pressure regulator that can go from a 20lb propane tank and connect to a torch made for a 1lb propane bottle?
Thanks,
JC
Posted
Look under propane burners at Amazon.com; they have hoses for use in 16 oz. fuel canisters; they can be converted, with a hose barb, to mate up with a regular propane hose and regulator, which you can also find there; total price is about $35.
Posted
That's a "I want to bake something; what temperature should I set my oven to?" sort of question.  I can't answer without know all the details of your set up and what you plan to do with it.
I can say that a torch made to run off a 1# canister of propane will not be suitable for any but the smallest of forges. (Single SOFT firebrick forge or micro forge types)
Posted
20 PSI is usually all the pressure your burner will need. The rest of the time you can bring that extra fiver from your wallet and ask yourself if it was worth it.
