June 27, 20188 yr While metal detecting underwater in the area that once was a whaling port I found this strange cone. Can anyone tell me if this is a old blacksmith cone? it has wood inside the cone like it was mounted on something.
June 27, 20188 yr Welcome... I always suggest reading this to get the best out of the forum. https://www.iforgeiron.com/topic/53873-read-this-first/ As far as the cone, it looks a little small for a blacksmith cone, probably was mounted on a dock/ship to tie off something.
June 27, 20188 yr As mentioned traditional blacksmiths cones are generally around 5' tall; modern ones are sometimes smaller and can even mount in a hardy hole. Can you use it as a cone in blacksmithing? Sure depending on how thick a side it has and what you want to do with it. I currently have cones made from the nose cone of a ballistic missile, test samples turned down into a cone for inspection, large valve cover for the stem, ...., pretty much anything steel and cone shape that will take some hitting...
