Just4u2c Posted May 11, 2018 Share Posted May 11, 2018 So I put my very first forge together. I have read a bunch, but obviously not enough as I need some opinions.. I wanted to start simple and work my way up instead of build something elaborate that didnt work.. So its refractory brick.. I have a blown propane setup that is using a hair dryer and 1 1/4 inch pipe.. The propane is going through a regulator and into a 3/8 copper pipe that goes into the side of the blower pipe and points down into the forge.. It seems like it is a great start but where the flame comes out of the pipe it is basically a clear to blue flame.. It ran for just a few minutes and i put a small piece of rebar in it. Within a minute or so it was red but only close to the opening and not at the end that was sitting under the blower.. My thoughts are this.. I have no exhaust, maybe that's the reason? The air volume is too much, but from a blow dryer? Pressure setting off on the propane? Or is it just designed wrong? I have seen other forges this size run these blower units.. I will continue to try things but thought you guys could lend an idea.. Btw.. this is not the end phase of this forge.. I just wanted simple at first to start with and then only change one thing at a time.. 20180509_191058.mp4 Quote Link to comment Share on other sites More sharing options...
swedefiddle Posted May 11, 2018 Share Posted May 11, 2018 Good Morning, You need to put more information in your Avatar, like where are you making a shadow? You need to find someone close to you, not your keyboard to help you. Your 3/8 copper pipe needs a restriction, to create pressure. Solder in a brass fitting like a mig-tip. I have used a Forge like yours for quite awhile, before I went for a better set-up. It needs more gas and less air, put a reostat on/in the hair dryer plug junction box. Bricks take 20 minutes or more to come up to temperature. Experiment and stay safe!!! Neil Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted May 11, 2018 Share Posted May 11, 2018 For a blown burner forge; have you looked at the peot forge plans? I have one and have accidentally melted steel with it. (and built it with Hans glaring over my shoulder...) Quote Link to comment Share on other sites More sharing options...
