April 17, 200818 yr I created an anvil saddle tonight based on this BP; BP0182 Anvil Saddle*-*I Forge Iron by Irnsrgn aka Jr Strasil I used the flat pick end from an old pick axe. Does it need to be heat treated / tempered? Or just normalized?
April 17, 200818 yr years ago when I used to rework picks for the RR section gangs, some time 50 or more at a time, I just quenched them when they were a dull red, one of my competitors used to do them, but he got them too hard and they broke and chipped bad. FWIW
April 17, 200818 yr Author Larry Looks Good Is ;that Your New Anvil? No that's the HF Russian sub. I should be ordering my new one first of next month. If I ordered it now, I'd be totally broke until then. Not a place I like to be!years ago when I used to rework picks for the RR section gangs, some time 50 or more at a time, I just quenched them when they were a dull red, one of my competitors used to do them, but he got them too hard and they broke and chipped bad. FWIW Do you think trying to use it having only normalized it will leave it too soft, liable to bend when hammered on?
April 17, 200818 yr Speaking of Russian subs, does HF still stock the 110#er? I heard they were no longer imported, but strange as it may sound, I still want one! :)
April 17, 200818 yr one way to find out Larry..if it does bend just straighten it out and try the heat treat
April 17, 200818 yr Speaking of Russian subs, does HF still stock the 110#er? I heard they were no longer imported, but strange as it may sound, I still want one! I think they are discontinued. I started calling stores in an ever increasing radius from home and found 3 in a store (Vineland NJ) +-50mi away. Best part, they were $56.95 each. I bought one. It would be worth a try from where your at. You'll need the HF # for the anvil. They are usually under the shelf somewhere, they can tell if they have in stock with the part number. I think I found the part number in a Google search. Good hunting! MIKE Frog's Dad
