New hobbiest needs help
Hello
i am new to this. My question is this. I have stacked walnut and brass with the last piece of brass towards the point of the blade. I want to silver solder the gap around the blade. I have used expoxy for the stacking and not sure if I will melt the expoxy while trying to solder the gap. Any help is greatly appreciated.
Thank you
Generally the epoxy will soften and possibly burn, silver solder is actually a low temp brazing process, hotter than solder but cooler than copper or brass. (One can cooler braze, then brass braze and finally silver solder in multi step assemblies)
Thanks guys,
My other option would be JB Weld but not sure how the dark grey would look
