Planejeff Posted October 19, 2017 Share Posted October 19, 2017 I have seen old buzz saw blade. The question is it possible to make a saw blade for a brush hog? What type metal? Best way to heat treat? Thanks Link to comment Share on other sites More sharing options...
John in Oly, WA Posted October 19, 2017 Share Posted October 19, 2017 Yeah, it's a crazy idea. Probably a good reason brush hog blades are designed the way they are considering what they hit in use. If you still want to be crazy and try to put a buzz saw blade on a brush hog, just find one that fits - and stand back while it's running...WAY BACK. Making a circular saw blade would involve some fine degree of precision and balancing, I'd think. Link to comment Share on other sites More sharing options...
mcostello Posted October 19, 2017 Share Posted October 19, 2017 Got 2 laying around if interested. Link to comment Share on other sites More sharing options...
ThomasPowers Posted October 19, 2017 Share Posted October 19, 2017 The crazy part is that they would be expensive to make and in use they would get mangled fast and NOT be repairable. Hard to mess up a standard hog blade that you couldn't fix with an angle grinder and if you do need to replace they are relatively cheap as they are relative simple. The weed cutters that use saw blades use small cheap ones and *you* are in charge of not hitting anything bad with them! Think of it: I hit a rock, I have to replace the blade; I hit a stump, I have to replace the blade, I kit some scrap metal I have to replace the blade. Link to comment Share on other sites More sharing options...
Please sign in to comment
