May 30, 20179 yr How many blades have you heat treated? 200? 400? More? Sample size is very important when you say you have never had these results... The surface needs to be cleaned up after heat treat and as long as it hardened you are good. Can't tell if you got it too hot, what is the grain size when you break it?
May 30, 20179 yr Author 13 hours ago, Steve Sells said: what am I missing? looks fine It was slick almost polished rite before I quenched it and came out with deep gouges and metal swirls in it
