JerryCarroll Posted March 31, 2017 Share Posted March 31, 2017 I have a request to repair a BBQ grill part that is torn on the edge flange in a curve that supports the curve. The metal is thin. Will braising stainless hold? Will my Hobart wire welder weld the stainless? I don't want to make a bigger gap experimenting. It's a very expensive grill . Thanks in advance. Jerry Quote Link to comment Share on other sites More sharing options...
Glenn Posted April 1, 2017 Share Posted April 1, 2017 You may want to contact Hobart and ask for their recommendations. Ask them if your welder can do the job, and the best way to approach the project. Is there any chance of getting similar material and doing some practice welds? Quote Link to comment Share on other sites More sharing options...
ironwolfforgeca Posted April 1, 2017 Share Posted April 1, 2017 do you have a tig welder or can get use of one ? rod to use is small OD silicon Bronze or stainless rod 308 or 316L depending on piece -- mite also use copper back bar for heat control need pic to help you better Steve's Welding & Fab Quote Link to comment Share on other sites More sharing options...
JerryCarroll Posted April 2, 2017 Author Share Posted April 2, 2017 I got some 309 sL rods and welded the split OK. The only thing I have used stainless rods for over the years is putting different metals together. One of my welders is an old Miller 225. Using the low side I can get the amps down to 20. I used 50 amps for the side table that got whacked falling over without any problems. Thank you fellows for your suggestions. Jerry Quote Link to comment Share on other sites More sharing options...
