BeaverNZ Posted March 12, 2017 Share Posted March 12, 2017 I am in the work shop today experimenting with forging and I had the thought of using a curcible of borax to heat up a billet for welding and if anyone had tried this. I know the borax would consume the crucible unless it was the correct material it would stop the billet from all oxidation so should result in consistant welds Cheers Beaver Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted March 12, 2017 Share Posted March 12, 2017 IIRC borax boils a bit under welding temps and that's one of the signs you are getting near so that;s sort of like heating steel to 125 degC by boiling it in water. You can see the colour of the flame get more orangish green when it's ready. I have known people to melt it to dip their hot piece in to flux it before welding. As I recall it was more work than you got better results. Quote Link to comment Share on other sites More sharing options...
BeaverNZ Posted March 12, 2017 Author Share Posted March 12, 2017 1 hour ago, ThomasPowers said: IIRC borax boils a bit under welding temps and that's one of the signs you are getting near so that;s sort of like heating steel to 125 degC by boiling it in water. You can see the colour of the flame get more orangish green when it's ready. I have known people to melt it to dip their hot piece in to flux it before welding. As I recall it was more work than you got better results. Cheers Thomas it was just a ramdom thought Quote Link to comment Share on other sites More sharing options...
