ACME identity
I recently purchased an ACME anvil, I believe it is  99 pounds since it has 99 stamped under the ACME, am not sure if it is a Trenton or Hay Budden. I have several photos. Also am a newbie so what would be a beginners size hammer to use on a 99 lb anvil. Also would anyone have an idea about when it was made?
Nice, I just found one myself today.
A good beginner hammer size is 2- 2 1/2 lbs. You can use a 4 lb hammer on a 99lb anvil as long as it is the HOT steel that you are hammering on.
Thanks for the information
May not be any formula carved in stone but a good rule of thumb is your anvil ought to be at least about 10x heavier than your heaviest hammer.
George
Great information, I plan to take a wire brush to the paint on it. Any other suggestions cleaning it
Best way to clean the anvil face, is to beat some HOT steel on it!
        Littleblacksmith
