hammerkid Posted February 13, 2008 Share Posted February 13, 2008 I was wondering if YOU HAVEto use a mill to get the holes cut out on the bender? Because I don`t thibk I can drill them out with my drill press LOL:p:D. If so could I get some one to cut it all out and send it to me and I`ll pay ya ( just cut the holes out I Forge Iron Quote Link to comment Share on other sites More sharing options...
aametalmaster Posted February 14, 2008 Share Posted February 14, 2008 Chris, That little bender is so cool. I will look it over and see what i can do for you, i have connections for stuff like that...Bob Quote Link to comment Share on other sites More sharing options...
aametalmaster Posted February 14, 2008 Share Posted February 14, 2008 One thing i would add is 5/16" holes drilled 360 degrees around the 8" plate to use as a stop when bending. Other than that its cool...Bob Quote Link to comment Share on other sites More sharing options...
R Funk Posted February 14, 2008 Share Posted February 14, 2008 The mill would be used as "drill press" with an ordinary drill bit with a precision locating table. A good machinist with a good drill press would be able to do the work on a drill press But an inexpereinced machinist would have a challenge to get all the holes and pins to fit in all the holes. Quote Link to comment Share on other sites More sharing options...
aametalmaster Posted February 14, 2008 Share Posted February 14, 2008 A mill would be clearly better, but if it was laid out properly and you had a nice 5/8" bit it would be easy. But most guys can't drill a bunch of 5/8" holes on home shop drill presses because they just don't run slow enough and the bit wobbles while drilling making nice star shaped holes. I added an extra small pulley on mine just to do 5/8" holes because i do a lot of reese hitch work. I also use a 4 flute drill bit that drills super nice holes but its 130 bucks...Bob Quote Link to comment Share on other sites More sharing options...
irnsrgn Posted February 14, 2008 Share Posted February 14, 2008 1. a simple jig with two holes drilled in it and a side piece welded on will work well to drill the holes, just drill the first hole then put a pin into it and one hole of the jig to drill the second. 2. drilled stop holes are never in the right place. there is a stop with a sq headed set screw shown that does a more efficient job. Quote Link to comment Share on other sites More sharing options...
aametalmaster Posted February 14, 2008 Share Posted February 14, 2008 2. drilled stop holes are never in the right place. there is a stop with a sq headed set screw shown that does a more efficient job. Yes it is efficient, but after years of using it you get lots of burrs and round holes galled into the steel then the stop dosen't seat well. Where a slotted flatbar washer could be adjusted to go between the holes at any setting. Oh well thats just me talking. But its still cool...Bob Quote Link to comment Share on other sites More sharing options...
hammerkid Posted February 15, 2008 Author Share Posted February 15, 2008 OK Bob I sent what I needed : football shaped die, well evrything in the 3rd pic. down on that bphttp://www.iforgeiron.com/blueprints-200-300/bp0204-grandpas-bender-modified.html Quote Link to comment Share on other sites More sharing options...
