feral-pagen Posted November 14, 2016 Share Posted November 14, 2016 I have a billet that i want to weld, and i have experience in this but it was with coal forges. Now i live in town and can't use a coal forge so i am in the process of putting together a propane forge. The one i'm starting out with is small, but that's not an issue really. I've used them for much smaller projects in the past, but now that i am having to use one exclusively i was wondering about burners. The one's i've used in the past were small and used a bernz-o-matic ts8000 torch head as the burner. i was wondering if this could work to get it up to weld temp, or if i should build my own burner first. Also, if i end up building a burner which design would work the best. i've been looking at a t burner and another design, but i can't remember what it's called. Any help would be appreciated. thanks Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted November 14, 2016 Share Posted November 14, 2016 Read the Burner's 101 thread, and find your answers; that's what it's for. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted November 14, 2016 Share Posted November 14, 2016 I'd find a local guy welding up billets in a propane forge and do likewise. Your 1000 pound billet will not heat to welding in a torch fired mini forge. (or basically there is a LOT of details you need to be sharing to get good answers) Quote Link to comment Share on other sites More sharing options...
feral-pagen Posted November 14, 2016 Author Share Posted November 14, 2016 ThomasPowers, i'm sorry, i should have been more detail oriented. It's a 33 layer billet made up of 25 layers of band saw blade and 8 layers of 11 gauge mild steel. it measures 8 inches long, one and one quarter inches wide, and about three inches thick. There are a couple smiths around, but they don't generally work with pattern welding. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted November 15, 2016 Share Posted November 15, 2016 I do not think a single torch burner will get 8" x 3" billet to welding temp in a forge big enough to hold one. Quote Link to comment Share on other sites More sharing options...
feral-pagen Posted November 15, 2016 Author Share Posted November 15, 2016 Thank you. i appreciate the input. I'll put one or two more burners in this weekend. I wish i still had my coal forge. this is both new and old territory for me. Quote Link to comment Share on other sites More sharing options...
