brian Posted January 29, 2008 Share Posted January 29, 2008 Know this is a difficult one to answer. What size flypress would suit me for general smithing?:confused: Mainly work hot mild steel up to 30 mm maximum . I am thinking 5 to 8 ton would suit but need all the advice I can get as I will have to get it shipped over and want to get it right first time. Quote Link to comment Share on other sites More sharing options...
imagedude Posted January 29, 2008 Share Posted January 29, 2008 I'd suggest that you get a size 6 or larger. Quote Link to comment Share on other sites More sharing options...
Dave Hammer Posted January 30, 2008 Share Posted January 30, 2008 On the forums I read, most smiths that have answered this type of question recommend a number 5 fly press. Larger flypresses require significantly more effort and the number 5 flypresses do the job for them. Quote Link to comment Share on other sites More sharing options...
gerald Posted January 30, 2008 Share Posted January 30, 2008 I have heard users say that swinging the 100 lb wheel of the P6 and larger presses gets old pretty quick. Quote Link to comment Share on other sites More sharing options...
imagedude Posted January 30, 2008 Share Posted January 30, 2008 Presses larger than size 6 are best used with 2 man operation but remember they you can work small stock with a large press but working large stock with a small press is a pain in the rear. Here's my size 4/5 press working 45mm stock. Quote Link to comment Share on other sites More sharing options...
stretch Posted January 30, 2008 Share Posted January 30, 2008 I have a 10 ton and love it. The only thing I wish I had thought of was a c frame press instead of the h frame I have. . Can be a lot more versatile. I have learned to use the h frame I have with great results. I agree, it is a lot easier to have one to big than to small. I find when you get a tool you start with small stuff and it gets more and more facinating (spelling) to forge larger and larger pieces. I think my flywheel is 234 lbs. LOVE IT Quote Link to comment Share on other sites More sharing options...
stretch Posted January 30, 2008 Share Posted January 30, 2008 These are a 3/4" shaft with about a 1 3/4" head done in one heat. I have tried to do with two people and almost killed him. To used to working alone. Quote Link to comment Share on other sites More sharing options...
