Kailthir Posted August 20, 2016 Share Posted August 20, 2016 I bought a Lincoln 140 HD Weld Pak. Using flux core wire, not gas rig. The wire feeds thru just fine, np... but there seems to be no arc.. no current. I have it all set up as per the instructions, even went online and watched a video or two to make sure I haven't missed anything. I don't understand, I returned the 125HD for the same reason. The tech said it was a bad gun. I cant be that unlucky to have two different models with bad guns? Anyone else run into this problem? Quote Link to comment Share on other sites More sharing options...
jmccustomknives Posted August 20, 2016 Share Posted August 20, 2016 Have you reversed the polarity? Quote Link to comment Share on other sites More sharing options...
Kailthir Posted August 20, 2016 Author Share Posted August 20, 2016 no, the tech and the instructions specifically say for flux core, the clam must be on the positive post and the gun on the negative. I don't want to switch them and blow it up or something lol. Its frustrating cause I want to build my forge but cant because I have welding to do. Quote Link to comment Share on other sites More sharing options...
jmccustomknives Posted August 20, 2016 Share Posted August 20, 2016 I ask because those machines come set up for hard wire. There's a diagram on the door for the wiring. Check and see if your set up right. I had a guy send a brand new Miller 140 in because it wouldn't weld. The repair shop sent it back with the polarity reversed and an $80 bill, because it's not the repairman's job to reverse the polarity. lol. Quote Link to comment Share on other sites More sharing options...
Kailthir Posted August 20, 2016 Author Share Posted August 20, 2016 According to the instructions and the door panel the polarity is correct Quote Link to comment Share on other sites More sharing options...
arkie Posted August 21, 2016 Share Posted August 21, 2016 I suggest you drift over to weldingweb.com and post your question/problem there. Lots of experienced welders there. Quote Link to comment Share on other sites More sharing options...
jmccustomknives Posted August 21, 2016 Share Posted August 21, 2016 The next thing I'd suggest is plugging it in on another circuit. Quote Link to comment Share on other sites More sharing options...
Jim Coke Posted August 21, 2016 Share Posted August 21, 2016 Greetings Kailthir, Sounds like a input voltage or connection problem .. Check the ground connection at both ends.. A simple continuity tester will work just fine... 220.. 110? A volt meter at the gun and ground connections will tell you if the machine has voltage available for the gun and ground.. I am sure you have a simple problem and are just overlooking something.. Good luck Forge on and make beautiful things Jim Quote Link to comment Share on other sites More sharing options...
