forge heat and material thickness
R.torres1993
Maximum temp would probably be an forge run off electric arc and might be set up to melt tungsten.  My propane forge with a single blown burner has melted steel in it before after I relined it.  All materials can be heated and worked with, some like food you don't heat above 400 deg F others like metals have ranges where they may be forgable or castable.
Your question is like "How many people can fit in my vehicle?"  where the answer can be between 0 and several thousand depending on the vehicle and other details.  Can you narrow it down any?
