R.torres1993 Posted March 3, 2016 Share Posted March 3, 2016 I was wondering what is the max temp a 5 gallon steel forge can reach and what meterials can be heated and woked with? Quote Link to comment Share on other sites More sharing options...
Glenn Posted March 3, 2016 Share Posted March 3, 2016 Your forge, your set up, your location, may vary. Forges typically can get hot enough to melt Carbon Steel 1425 - 1540*C or 2600 - 2800*F Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted March 3, 2016 Share Posted March 3, 2016 Maximum temp would probably be an forge run off electric arc and might be set up to melt tungsten. My propane forge with a single blown burner has melted steel in it before after I relined it. All materials can be heated and worked with, some like food you don't heat above 400 deg F others like metals have ranges where they may be forgable or castable. Your question is like "How many people can fit in my vehicle?" where the answer can be between 0 and several thousand depending on the vehicle and other details. Can you narrow it down any? Quote Link to comment Share on other sites More sharing options...
R.torres1993 Posted March 4, 2016 Author Share Posted March 4, 2016 thanks for the advice guys together I got the info I needed Quote Link to comment Share on other sites More sharing options...
