January 24, 201610 yr Well broke my cheapo HE vise today. Broke out a used Babco 605. Anyone have one. Missing a jaw plate trying to figure out how to put in a replacement. Screw holes are shot. Wondering if I preheat would it weld in?
January 24, 201610 yr Author Ok guys I see cast iron, ductile iron, and forged stellar vises. Pros and Cons. Some of these buggers are WAY expensive???
January 24, 201610 yr Chase the threads in the holes and replace the insert. It's a basic shop skill, you should have no problem finding a how to online. Frosty The Lucky.
January 24, 201610 yr Author Problem somebody tried a sloppy weld and snagged out both factory holes. Would need to drill and tap from scratch
January 24, 201610 yr At the risk of sounding like a heretic,....... I had a similar problem on a vice that I needed to use in a hurry and some chaps were busy on my other vices so I just stuck in a jaw with 'hot melt glue ' as a 'quick fix' that was a few years ago and it's still there. Melts a bit when you stick in hot metal but it hasn't slipped yet.
January 24, 201610 yr Author Wow. Never thought of that. I was thinking high grade metallic apoxy. Hot glue LOT CHEAPET.
January 24, 201610 yr 2 hours ago, Ernie42141 said: Problem somebody tried a sloppy weld and snagged out both factory holes. Would need to drill and tap from scratch Yeah, so? It's rare you can just chase buggered threads by running the same cap in them. Basic shop stuff. Hot glue is fair game as well, though I'd use epoxy, it's NOT like you'll be hammering on it. Frosty The Lucky.
January 24, 201610 yr 14 minutes ago, Frosty said: it's NOT like you'll be hammering on it. Frosty The Lucky. Huh? It looked like a vice to me? Have I got this all wrong?
January 25, 201610 yr 4 hours ago, ianinsa said: Huh? It looked like a vice to me? Have I got this all wrong? Hammering on cast iron is indeed a vice, so hammering on that viSe looks just like the vice it is. I can explain that if you need Ian. Just let me know. Frosty The Lucky.
January 25, 201610 yr But it 'looks' like a versatile vice....ie. A 'vice versa?' seems like I must have got it backwards
January 25, 201610 yr 4 hours ago, ianinsa said: But it 'looks' like a versatile vice....ie. A 'vice versa?' seems like I must have got it backwards Nothing new. It must be the clockwise Coriolis effect living that side of the equator. Frosty The Lucky.
