Bull Nose Lathe Center Made
I always am turning a chunk of pipe or something with a big hole in it and needed a bull nose center. I don't like to buy anything i can make so i made one with 2 bearings from the farm store and a couple chunks of steel. First i turned an arbor with a #2MT on it then turned it to fit the bearing bore. Then i turned the nose taper then bored the hole for the bearing OD. Works great on a chunk of rusty 2" black pipe. And it was only 20 bucks and some time...Bob
4481.attach
4482.attach
4484.attach
4485.attach
4486.attach
4487.attach
4488.attach
4489.attach
  • 1 year later...
Bob,
Usually a live bull nose is made for the tail stock. Did you change the taper on it after you were done?
Jay
Jay, It is in the tailstock. The first pic i have the #2 MT in a #3 MT sleeve to hold it in my headstock while working on it....Bob
Bob I was in a hurry didn't notice you were showing it in action with a tube getting cut. It is a nice job. I got lucky on the last lathe I bought. I almost got more tooling than lathe. Take care Jay
I need one of those soooooo bad! thanks for the post/inspiration!!!!
Oh, buy the way looks great!
Neat project! I could use one of those for my HF Mini. I'm just not sure I could get the taper accurate enough. Can you buy tapers somewhere to use as a starter for projects like this?? I supposed, on the other hand, by T&E, I could get the taper right. It would just take longer and that fits right in to my POA as a rule :D
I have used some old tapered drill bits for projects. Just wack off the bit and weld a chunk of steel then turn it to suit. I will be turning some #2 MT blanks soon i can make extra ones while i am set up...Bob
12597.attach
