August 30, 201510 yr I have a 30 ton H frame press that's been collecting dirt for awhile and was thinking about getting one of those harbor freight 20 ton air bottle jacks for it. So far I've read a handful of topics for those little air hydraulic presses but everyone seems set on building their own press frame for them. Is it a wise idea to use this 30 ton frame as a 20 ton forging press host? For less then $100 and hardly any time on my hands it sounds like a great idea after seeing what these small presses do on youtube.
August 30, 201510 yr I can't see a reason why not. The press is more than stout enough for a smaller jack. I'm personally not a great fan of HF tools myself as most really aren't worth the money you pay for them. I can't say about that jack, but the floor jacks I've used weren't worth wasting money on as most failed or leaked within 6 months.
August 31, 201510 yr Author I know what you mean, harbor freight usually makes me cringe but it looks like people have had luck with them. I was mainly concerned about the play in the top ram that comes down, there's maybe an 1/8" of play back and forth. Could that cause something to spit out at me?
August 31, 201510 yr for a forging press you need speed, count how many inches a second your jack can go to see if it is suitable
August 31, 201510 yr Author This isn't going to be a serious endeavor, just something to pass the time until I actually put time aside to build a real press. I'll be more than happy if it will squeeze a hot piece of metal faster then I can forge it by hand.
September 1, 201510 yr I built one. Made 2 harley chain knives on it and several random pattern Damascus knives with it.Just remember you have 20 tons of pressure.Gotta keep the work hot.What the heck you can always use a new jack right?Take CareTJ SmithI did make a 20 ton though just so you know Once your're hooked on damascus you 've had it.
